::GetCurrentSelection
::model::mdlComboBoxDM:GetCurrentSelection path value
MotionView Tcl GUI
This command gets the currently selected entry in an mdlComboBoxDM widget.
path
The full path to the mdlComboBoxDM of interest. This argument is the return value of the ::model::mdlComboBoxDM procedure used to create an mdlComboBoxDM.
value
Boolean value, defaults to false if not provided.
True
Returns the value of the selection (“DISP” for example).
False
Returns the label of the selection (“Displacement” for example).
To get the current selection of the value of an mdlComboBoxDM widget:
::model::GetClientHandle clnt
clnt GetModelHandle mdl
clnt ReleaseHandle
mdl InterpretEntity entMot Motion mot_0 "\"Motion 0\""
mdl ReleaseHandle
set dlg [toplevel .dlg]
set frm [frame $dlg.frm -padx 10 -pady 10]
grid $frm -row 0 -column 0 -sticky nesw
set data { "DISP" "Displacement" "VEL" "Velocity" "ACCL" "Acceleration" }
set motion [::model::mdlComboBoxDM .dlg.frm.motion entMot "itype" $data -label "Type:"]
grid $motion -row 0 -column 0
set value [ ::model::mdlComboBoxDM::GetCurrentSelection $motion true]
entMot ReleaseHandle
None.
