::SetCurrentLRTab
This command is used to set which LEFT/RIGHT tab of a panel is selected if any panel’s selected entity is a pair.
::model::SetCurrentLRTab argTab
MotionView Tcl
argTab
We need to pass either “LEFT/RIGHT” or “L/R” as input to make the respective tab as current.
::model::GetHandleFromFullVarname mod MODEL
mod InterpretEntity pthandle PointPair p_0 "\"Point0\""
::model::GetCurrentLRTab  # It returns Left tab as active
::model::SetCurrentLRTab RIGHT
::model::GetCurrentLRTab  # It returns Right tab as active
pthandle ReleaseHandle
mod ReleaseHandle
Returns 1 if successful, otherwise a 0 will be returned.
