Program with HyperWorks Tcl/Tk Command Tutorials
Make a proc:
- A proc is a function that, when called, will run through all the commands made within it.
- The two words within the { } are the inputs (if there are inputs
needed). These inputs will be used in the function. For example, the
fileName input would be the file used in the function.
- When calling the values of these inputs within the function, use a $ symbol followed by the variable name.
- The last { on the proc line denotes the beginning of the code within the function. There must be another } at the very end of the written code to end the proc.
proc ShowCurves {fileName amount} { -
hwi is the first parent handle, which connects every API together.
- First, get the session handle from the hwi handle, and then you can delve deeper to find the APIs needed.
- For the basics in understanding HyperWorks APIs, read Program with HyperWorks APIs for Beginners.
hwi GetSessionHandle sess -
Get the project handle.
sess GetProjectHandle proj -
Open up the data file handle of the file that is input when the function is
called.
- The $ symbol tells the program to use the value of the variable, in this case, the variable is the input fileName.
sess GetDataFileHandle data $fileName -
Each of the “foreach” loops runs through the input data.
- For example, the first "foreach" loops through each value in the datatype list of the data file.
- The same occurs for the request list and the component list.
- This way, every possible combination of datatype, request, and component are used.
foreach value [data GetDataTypeList false] { foreach request [data GetRequestList $value false] { foreach component [data GetComponentList $value false] { -
Next, get the correct page, window, and client, and set the correct client type
before getting its handle.
- This adds a curve for every datatype, request, and component, and gets the handle of the curve that was just made.
proj GetPageHandle p1 1 p1 GetWindowHandle w1 1 w1 SetClientType Plot w1 GetClientHandle plot -
By setting the added curve as cn, you can grab the handle each time without
knowing exactly which curve number it is.
- This code once again uses the $ symbol, as to use the value of the variable cn.
set cn [plot AddCurve] plot GetCurveHandle c1 $cn -
Set up the curve based on the file. It uses the datatype, request, and
component set in the loop.
c1 GetVectorHandle xv x xv SetType File xv SetFilename $fileName c1 GetVectorHandle yv y yv SetType File yv SetFilename $fileName yv SetDataType $value yv SetRequest $request yv SetComponent $component -
Draw the cursor after recalculating and scaling it.
plot Recalculate plot Autoscale plot Draw -
Find the min and max Y values and set them to the specific variables
maxY and minY.
c1 AddCursor c1 GetCursorHandle cur 1 cur FindGlobalMax y set maxY [cur GetY] cur FindGlobalMin y set minY [cur GetY] -
Find the difference between the min and max y value by taking the absolute
value of the maxY minus the minY.
set diff [expr abs($maxY-$minY)] -
If the difference is less than the amount you input, the curve’s visibility
will be turned off.
if {$diff < $amount} { c1 SetVisibility false } -
Release all the handles so they can be grabbed once again when the loop begins
again.
p1 ReleaseHandle w1 ReleaseHandle plot ReleaseHandle c1 ReleaseHandle cur ReleaseHandle xv ReleaseHandle yv ReleaseHandle -
Once everything is done, the loops are closed and the proc is closed as
well.
