Adds a new analysis from an existing data file.
Adds a new analysis from an existing or new definition/data file.
Evaluates all of the expressions in the model to update the values.
Exports a model into a data only, wizard only, or a data and wizard file.
Gets the list of all the available analysis variable names.
Gets the variable name of the current analysis.
Gets a handle of the client.
ON THIS PAGE
ON THIS PAGE
