::DrawActiveWindow
This command is used to draw the active window in the active page. There is an option to “fit” all of the model contents within the graphic area.
::model::DrawActiveWindow [argOrient]
MotionView Tcl
argOrient
The only supported value for this optional argument is “FIT”. If it is anything else it is ignored.
::model::GetHandleFromFullVarname selhandle MODEL;
selhandle InterpretEntity pnt Point p_0 "\"Point0\""
selhandle InterpretSet SetPoint p_0 10 20 30
::model::EvaluateModel
::model::DrawActiveWindow FIT
On successful execution of the command it will draw the model in the active window and active page.
