/ANIM/SHELL/SIG1H
Engine Keyword Generates animation files containing the first normalized principal stress as function of a shell element integration point.
/ANIM/SHELL/SIG1H/Keyword4
Keyword4 | Output location.
- In case of BATOZ shell element, the value is the average value of the Gauss points in the layer.
