/ANIM/SHELL/IDPLY/EPSP
Engine Keyword Generates animation files containing plastic strain for shell elements that use ply-based composite properties, /PROP/STACK (TYPE17), /PROP/TYPE51, or /PCOMPP.
/ANIM/SHELL/IDPLY/EPSP/Keyword5/Keyword6
| Keyword5 | Ply output:
| Keyword6 | Output location. Only used if Keyword5 is entered.
- Ply ID number is prop_ID from /PROP/TYPE19 (PLY)/prop_ID or ply_ID from /PLY/ply_ID.
- For fully integrated BATOZ shells, Ishell=12, the output value is the average of the in-plane Gauss points.
