/ANIM/SHELL/PHI
Engine Keyword Generates animation files containing angle between element skew and direction 1 orthotropy.
/ANIM/SHELL/PHI/Keyword4
Keyword4 | Output location.
- An N/A value will be output for any layer number that is requested, but does not exist in the model.
