/ANIM/SHELL/NXTFACTOR
Engine Keyword Generates animation files containing the instability factor of NXT failure model as function of a shell element integration point.
/ANIM/SHELL/NXTFACTOR/Keyword4
Keyword4 | Output location.
- In case of BATOZ shell element, the value is the average value of the Gauss points in the layer.
