Urban Communication, 802.11g
Calculate network planning for 802.11g using three different methods in an urban scenario.
The WinProp Getting Started Guide contains step-by-step instructions on how to get started with WinProp.
The Altair installation directory contains a collection of examples that shows you WinProp concepts and essentials.
Simple examples demonstrating databases, antenna patterns and air interfaces.
Simple examples demonstrating propagation projects.
View examples that demonstrate network planning projects.
The network planning of an indoor scenario is investigated. The geometry is a large convention center.
The network planning of an urban scenario with 2.5 G is investigated.
The network planning of a rural/suburban scenario with 2.5G is investigated.
The network planning of an indoor scenario is investigated. The model consists of a large multi-story building.
The network planning of an urban scenario is investigated. The geometry is described by extruded polygons that represent urban buildings.
Calculate network planning for 802.11g using three different methods inside a large building.
The network planning of a local area network in an urban scenario is investigated. The dominant path model (DPM) is used.
The network planning of a local area network in an urban scenario is investigated. The intelligent ray tracing model (IRT) method is used.
The network planning of a local area network in an urban scenario is investigated. The knife edge diffraction method is used.
Perform network planning using code division multiple access (CDMA) EVDO inside a single-story building.
Calculate the power coverage of four digital video broadcasting transmitters in a rural/suburban scenario.
Determine whether base stations exceed exposure limits in a rural scenario.
Perform indoor network planning for long term evolution (LTE).
Perform network planning for WiMAX in a rural mobile scenario.
Perform network planning for long term evolution (LTE) using multiple input multiple output (MIMO) in an indoor scenario.
Perform network planning for long term evolution (LTE) in an indoor scenario of a two-story building.
Perform indoor network planning for long term evolution (LTE) using multiple input multiple output (MIMO).
Perform indoor network planning with LTE and leaky feeder cables.
Perform indoor network planning with LTE and generate a Monte Carlo report.
Perform network planning for an urban scenario using long-term evolution (LTE).
Perform urban network planning with LTE and generate a Monte Carlo report.
Perform indoor network planning with MIMO using post-processing.
Perform traffic simulation and export a report using Monte Carlo analysis for trans-European trunked radio (TETRA).
Perform TETRA network planning in an urban scenario.
Perform network analysis for ultra-wide band (UWB) frequencies in an indoor scenario.
Perform network analysis for indoor WiMAX coverage.
Perform network analysis for a WiMAX air interface in a rural/suburban scenario for fixed communications, such as “the last mile” to a residential internet subscriber.
Perform network planning for fixed WiMAX coverage in an urban scenario.
Perform network planning for mobile WiMAX coverage in an urban scenario.
Perform network planning for the internet of things (IoT) in an urban scenario.
Simple examples demonstrating time-variant projects.
Simple examples demonstrating connectivity projects using CoMan.
Simple examples demonstrating optimization projects using OptMan.
Simple examples demonstrating satellites.
WinProp is a complete suite of tools in the domain of wireless propagation and radio network planning. With applications ranging from satellite to terrestrial, from rural via urban to indoor radio links, WinProp’s innovative wave propagation models combine accuracy with short computation time.
View the typical workflows when working with propagation simulations in specific scenarios, how to add a network planning to a propagation simulation, include a receiver pattern, set up a time-variant scenario, include multiple-input multiple-output (MIMO) at both the base station and the mobile station, connectivity analysis of sensor networks and optimization.
The WallMan component offers a convenient facility to generate and edit vector building databases.
The TuMan tool enables you to generate and modify tunnel scenarios.
Use AMan to generate, edit and analyze a single antenna. Superimpose multiple antennas radiating similar signals to determine the actual antenna pattern while taking into consideration the local environment.
The ProMan component includes wave propagation models for different scenarios and network planning simulators for various air interfaces.
WinProp includes empirical and semi-empirical models (calibration with measurements possible), rigorous 3D ray-tracing models as well as the unique dominant path model (DPM).
In WinProp various air interfaces and applications are pre-defined: broadcasting, cellular, wireless access, WiFi, sensor networks, ICNIRP and EM compliance.
The OptMan component allows the automatic optimization of orientations of antennas in cellular networks to achieve various targets.
The CoMan component allows the simulation of the reliability and connectivity in wireless mesh / sensor networks.
The WinProp utilities consist of the Launcher utility and the Updater.
