WiMAX Rural Mobile
Perform network planning for WiMAX in a rural mobile scenario.
WiMAX Standard and Definition
This is an example of the WiMAX air interface in a rural/suburban scenario for mobile communications such as communication between base stations and vehicles. WiMAX refers to the IEEE 802.16 standard - a family of wireless networks standards formulated by the WiMAX forum. The IEEE 802.16e (mobile broadband wireless access) Wimax standard is used in this model. WiMAX is similar to long-range Wi-Fi, but it can enable usage at much greater distances.
Model Type
![](../../../../../images/winprop/example_guide/network_planning_projects/wimax_rural_mobile/topographical_database.png)
Figure 1. Topographical database.
![](../../../../../images/winprop/example_guide/network_planning_projects/wimax_rural_mobile/clutter_database.png)
Figure 2. Clutter database.
Sites and Antennas
Air Interface
Computational Method
The computational method is selected on the Computation tab. The dominant path model (DPM) was selected for the computation. The method focuses on the most relevant path, which leads to shorter computation times.
Results
Propagation results show at every location the power received by a hypothetical isotropic receiver from each transmitting antenna. Propagation results also include field strength and path loss. Results are calculated for a single prediction plane at 1.5 m height.
![](../../../../../images/winprop/example_guide/network_planning_projects/wimax_rural_mobile/dl_max_throughput.png)
Figure 3. Maximum throughput in the downlink for receivers at 1.5 m height.
