Indoor Communication, 802.11g with DPM
The network planning of a local area network planning project in an indoor scenario is investigated. The model is a multi-floor building. The dominant path model (DPM) method is used.
Sites and Antennas
There are eight antenna sites at different locations and elevations in the building for best signal coverage. Each antenna site has one isotropic antenna. They are placed at four levels of height, that are 2.5 m, 6.2 m, 9.9 m, and 13.6 m. Four different carrier frequencies around 2.4 GHz are used to minimize interference.
1.500 5.200 8.900 12.600
![](../../../../images/winprop/example_guide/network_planning_projects/comm_3g_indoor/indoor_80211_heights_dpm.png)
Figure 1. Selectable heights to view the prediction.
Air Interface
Computational Method
Results
![](../../../../images/winprop/example_guide/network_planning_projects/comm_80211_indoor/indoor_80211_heights_dpm.png)
Figure 2. Selectable height levels for the prediction.
The type of network simulation used is a static simulation (homogeneous traffic per cell). The network simulation calculates results like cell area, site area, best server, and maximum data rate. The network simulation calculates the maximum receiver power and the maximum signal-to-noise-and-interference ratio (SNIR) for all modulation and coding schemes used in this model, for both downlink and uplink.
As an example, the image below shows the uplink SNIR, at the prediction height 8.9 m, for one of the modulation schemes.
![](../../../../images/winprop/example_guide/network_planning_projects/comm_80211_indoor/indoor_80211_results_dpm.png)
Figure 3. Uplink SNIR for the BPSK low modulation scheme at a height of 8.9 m.
