The central difference algorithm corresponds to the Newmark algorithm with
and
so that
Newarks Method,
Equation 7 and
Equation 8 become:
(1)
(2)
with
the time step between
and
It is easy to show that the central difference
algorithm
1 can be changed to an equivalent form with 3 time
steps, if the time step is constant.
(3)
From the algorithmic point of view, it is, however, more efficient
to use velocities at half of the time step:
(4)
so that:
(5)
(6)
Time integration is explicit, in that if acceleration
is known (
Combine Modal Reduction), the future velocities and
displacements are calculated from past (known) values in time:
is obtained from Equation 5: (7)
The same formulation is used for rotational velocities.
is obtained from Equation 4: (8)
The accuracy of the scheme is of
order, that is, if the time step is halved, the amount of
error in the calculation is one quarter of the original. The time step
may be variable from one cycle to another. It
is recalculated after internal forces have been computed.
