/RADIATION
Block Format Keyword Describes the imposed radiation flux to environment.
/RADIATION/Radiative_Flux_ID/unit_ID
Radiative_Flux_title
surf_IDT fct_IDT sens_ID
Ascalex FscaleY Tstart Tstop ε
Radiative_Flux_ID Imposed radiative flux block identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
Radiative_Flux_title Imposed radiative flux block title.
surf_IDT Identifier for surface which absorbs thermal radiation.
(Integer)
fct_IDT Time function identifier for the temperature of heat source T ∞ .
(Integer)
sens_ID Sensor identifier.
(Integer)
Ascalex Abscissa (time) scale factor for fct_IDT.
Default = 1.0 (Real)
[ s ]
FscaleY Ordinate (temperature) scale factor for fct_IDT.
[ K ]
Tstart Start time.
(Real)
[ s ]
Tstop Stop time.
(Real)
[ s ]
ε Emissivity 0 < ε < 1 .
(Real)
Example (Thermal Loading)
#RADIOSS STARTER
/UNIT/12
unit for imposed radiation load
Mg                  mm                   s
/RADIATION/1/12
RADIATION from heat source
#  surf_ID    fct_ID   sens_ID
5      2003         0
#             ASCALE              FSCALE              TSTART               TSTOP                   E
0                   0                   0                   0                0.15
/FUNCT/2003
temperature of heat source function of time
#                  X                   Y
0                 773
1                 700
#ENDDATA
  1. The radiation flux is calculated using:
    (1)
    φ = ε σ ( T 4 − T ∞ 4 )
    Where,
    T
    Temperature of the surface (surf_IDT) which absorbs thermal radiation
    σ
    The Stefan-Boltzmann constant
    (2)
    σ = 5 .669 x 10 -8   W m 2 ⋅ K 4
    Since σ is a constant which depends on the units, the unit system must be set correctly in /BEGIN and in the optional unit_ID which is used by the radiative flux block.
  2. Thermal radiation is only compatible with the finite element formulation for heat transfer.
  3. /RADIATION is not compatible with ALE applications (/ALE, /EULER). Thermal radiation will not be applied to ALE nodes or ALE elements.
