/MOVE_FUNCT
Block Format Keyword This describes the function scale and shift.
/MOVE_FUNCT/fct_ID
move_funct_title
Ascalex Fscaley Ashiftx Fshifty
fct_ID Function identifier
(Integer, maximum 10 digits)
move_funct_title Move function title
Ascalex Abscissa scale factor
Default = 1.0 (Real)
Fscaley Ordinate scale factor
Ashiftx Abscissa shift value
Default = 0.0 (Real)
Fshifty Ordinate shift value
  1. The function linked to this option is scaled first and shifted afterwards, as follows:
    (1)
    X n e w = X o l d A s c a l e x + A s h i f t x
    (2)
    Y n e w = Y o l d F s c a l e y + F s h i f t y
    with X o l d and Y o l d are values from function fct_ID.
  2. It is recommended that the final list of abscissa value in the function be increased (which means the abscissa value in the function needs to be greater than the previous abscissa value).
