/GRTRUS/PROP
Block Format Keyword Describes the truss property groups which belong to given properties.
/GRTRUS/PROP/grtruss_ID/unit_ID | |||||||||
grtruss_title | |||||||||
item_ID1 | item_ID2 | item_ID3 | item_ID4 | item_ID5 | item_ID6 | item_ID7 | item_ID8 | item_ID9 | item_ID10 |
grtruss_ID | Truss group identifier (Integer, maximum 10 digits) |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
grtruss_title | Truss group title (Character, maximum 100 characters) |
item_ID1, item_ID2,... item_IDn | List of property
identifiers (Integer) |
- If item_ID is a negative number, the item number is deleted from the group.
