/GRTRUS/BOX or /GRTRUS/BOX2
Block Format Keyword Describes the truss box groups which are inside the box.
Only one box_ID is allowed:
/GRTRUS/BOX/grtruss_ID/unit_ID or /GRTRUS/BOX2/grtruss_ID/unit_ID
grtruss_title
box_ID
grtruss_ID Truss group identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
grtruss_title Truss group title
box_ID Box identifier, which is defined in Boxes
  1. If type is BOX, all elements having all nodes inside the box or on its surface are selected.
    If type is BOX2, all elements with at least one node inside the box or on its external surface are selected.
