/GRTRIA/GENE
Block Format Keyword Generate a group of triangles (/TRIA) by listing the first and last element IDs in the range.
For each list, enter first and last triangle identifier (any number of lists may be input, up to 5 per Line). All 2D solid triangles (/TRIA) with identifiers between first_ID and last_ID are selected.
/GRTRIA/GENE/grtria_ID/unit_ID
grtria_title
first_ID1 last_ID1 first_ID2 last_ID2 first_ID3 last_ID3 first_ID4 last_ID4 first_IDn last_IDn
grtria_ID Group identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
grtria_title Group title
first_ID1, last_ID1,...first_IDn, last_IDn List of first and last triangle identifiers
(Integer)
