/GRTRIA/GEN_INCR
Block Format Keyword Generates a group of triangles by listing the first and last triangle IDs in the range with a user-defined increment value.
/GRTRIA/GEN_INCR/grtria_ID/unit_ID | |||||||||
grtria_title | |||||||||
first_ID | last_ID | Incr |
grtria_ID | 2D solid triangle group
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
grtria_title | 2D solid triangle group
first_ID | First 2D solid triangle
element identifier in the list. (Integer) |
last_ID | Last 2D solid triangle
Incr | Increment value of the
list generation from first_ID to
last_ID. Default = 1 (Integer) |
- The group includes first_ID, first_ID+Incr, first_ID+2*Incr, first_ID+3*Incr, … continuing through last_ID.
- Multiple first_ID, last_ID, and Incr lines can be defined in one block.
