/GRSH3N/GRSH3N
Block Format Keyword Describes the 3 node shell groups which are selected from other 3-node shell groups.
Enter selected items numbers (any number may be input, 10 per Line)
/GRSH3N/GRSH3N/grsh3n_ID/unit_ID
grsh3n_title
item_ID1 item_ID2 item_ID3 item_ID4 item_ID5 item_ID6 item_ID7 item_ID8 item_ID9 item_ID10
grsh3n_ID 3 node shell group identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
grsh3n_title 3 node shell group title
item_ID1, item_ID2,..., item_IDn List of 3-node shell group identifiers
(Integer)
  1. The 3 node shell groups cannot contain 4 node shell elements (use /GRSHEL instead).
