/GRSH3N/BOX or /GRSH3N/BOX2
Block Format Keyword Describes the 3 node shell groups which are inside the box.
Only one box_ID is allowed:
/GRSH3N/BOX/grsh3n_ID/unit_ID or /GRSH3N/BOX2/grsh3n_ID/unit_ID
grsh3n_title
box_ID
grsh3n_ID 3 node shell group identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
grsh3n_title 3 node shell group title
box_ID Box identifier, which is defined in Boxes
  1. The 3 node shell groups cannot contain 4 node shell elements (use /GRSHEL instead).
  2. If type is BOX, all elements having all nodes inside the box or on its surface are selected.
    If type is BOX2, all elements with at least one node inside the box or on its external surface are selected.
