/GRQUAD/GEN_INCR
Block Format Keyword Generates a group of quads by listing the first and last quads IDs in the range with a user-defined increment value.
Generate a list of entities that starts with first_ID and includes entities every Incr after first_ID until last_ID.
/GRQUAD/GEN_INCR/grquad_ID/unit_ID
grquad_title
first_ID last_ID Incr
grquad_ID Quad group identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
grquad_title Quad group title
first_ID First quad element identifier in the list.
(Integer)
last_ID Last quad element identifier in the list.
(Integer)
Incr Increment value of the list generation from first_ID to last_ID.
Default = 1 (Integer)
  1. The group includes first_ID, first_ID+Incr, first_ID+2*Incr, first_ID+3*Incr, … continuing through last_ID.
  2. Multiple first_ID, last_ID, and Incr lines can be defined in one block.
