/GRQUAD/BOX or /GRQUAD/BOX2
Block Format Keyword Describes the quad groups are inside the box.
Only one box_ID is allowed:
/GRQUAD/BOX/grquad_ID/unit_ID or /GRQUAD/BOX2/grquad_ID/unit_ID
grquad_title
box_ID
grquad_ID Quad group identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
grquad_title Quad group title
box_ID Box identifier, which is defined in Boxes
  1. If type is BOX, all elements having all nodes inside the box or on its surface are selected.
    If type is BOX2, all elements with at least one node inside the box or on its external surface are selected.
