/GRBRIC/GENE
Block Format Keyword Generate a group of beam elements by listing the first and last element IDs in the range.
For each list, enter first beam and last beam (any number of lists may be input, up to 5 per Line). All beams between first_ID and last_ID are selected.
/GRBRIC/GENE/grbric_ID/unit_ID | |||||||||
grbric_title | |||||||||
first_ID1 | last_ID1 | first_ID2 | last_ID2 | first_ID3 | last_ID3 | first_ID4 | last_ID4 | first_IDn | last_IDn |
grbric_ID | Brick group
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
grbric_title | Brick group
first_ID1, last_ID1,..., first_IDn, last_IDn | List of first and last
brick identifiers (Integer) |
