/GRBRIC/BRIC
Block Format Keyword Describes the brick number groups.
Enter selected items numbers (any number may be input, 10 per Line)
/GRBRIC/BRIC/grbric_ID/unit_ID
grbric_title
item_ID1 item_ID2 item_ID3 item_ID4 item_ID5 item_ID6 item_ID7 item_ID8 item_ID9 item_ID10
grbric_ID Brick group identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
grbric_title Brick group title
item_ID1, item_ID2,...,item_IDn List of brick identifiers
(Integer)
  1. If item_ID is a negative number, the item number is deleted from the group.
  2. Brick groups may include tetrahedron and hexahedron.
