Radioss Files
Input Format
The input format (V41, V44, V51, V90, and so on) corresponds to the format of the Radioss input data file, whose name is RunnameD00 for input formats up to V44 or Runname_0000.rad for input formats coming from V51 or higher.
For input formats up to V44, the input format is declared at the first line of the Starter input file. This conforms to the version of the input manual.
For input formats from V51 onwards, the input format is declared in the keyword /BEGIN, which must be the first uncommented line after the line: “#RADIOSS Starter”.
For every new Radioss main release (V41, V44, V51, V90, and so on), a new input manual is provided, which presents the characteristics of the new input format, and information on new keywords.
By ascending compatibility, a RunnamD00 or Runname_0000.rad file conforming to a given manual will be read normally by the next Radioss release (but not the opposite).
For instance, a file with format V41 will be read normally by V44 of Radioss, while a file with format V42 cannot be used with V41. In this last case, an error message is given by Radioss Starter:
** ERROR IN INPUT FORMAT
INPUT VERSION 42 IS NOT SUPPORTED
Version 12.0 and After
Radioss versions 12.0 and after are all based on 12x extension format.
4x Extension Format 12x Extension Format Type Format Remark Read by Written by
RunnameD00 Runname_0000.rad Starter input ASCII   Starter HyperCrash
HyperMesh
RunnameDnn Runname_run#.rad Engine input ASCII   Engine User
RunnameRnn Runname_run#_cpu # [_C].rst Restart file Any Default binary Engine Starter
Engine
RunnameRnn RunnameAnnn Animation IEEE binary   HyperView Engine
N/A Runname.h3d Animation H3D   HyperView Engine (starting in 2018) or HvTrans thru run script
RunnameTnn if Radioss Engine option /TH/VERS/41 is used (default):
RunnameTnn
Time history Any Default IEEE binary HyperGraph Engine
RunnameTnnx if Radioss Engine option /TH/VERS/41 is used (default):
RunnameTnnx
if Radioss Engine option /TH/VERS/51 is used:
Runname_run#_x.thy
“x”: letter (a to i)
Runname@Tnn Runname_run#_@.thy MNOISE file Any   HyperGraph Engine
RunnameLnn Runname_run#.out Listing ASCII     Engine
RunnameLnn Runname_nnnn.sty or RunnameYnnn
according to the /IOFLAG keyword
if Irootyy = 2:
RunnameYnnn
if Irootyy ≠ 2:
Runname_#run.sty
Output ASCII   Starter Engine
  Runname_run#.sta State file ASCII   Starter Engine
RunnameCnn Runname_run#.ctl Control files ASCII   Engine User
run# : RADIOSS run number (four digits) from 0000 to 9999
cpu # : number of processors (four digits)
cpu # = 0000 = SMP RADIOSS Version
cpu # = 0001 to 9999 = MPP (SPMD) RADIOSS Version
C: restart letter (see /RFILE option in the RADIOSS Engine manual)
In case of Single Input File, Engine options can be added into Starter file. Refer to Single File Input for details.
Version 9.0
Some Radioss 9x extensions were modified:
Runname_run#.lis becomes Runname_run#.out
Runname_nnnn.out becomes Runname_nnnn.sty
9x extension Type Format Remark Read by Written by
HyperMesh
Runname_0000_a.rad Starter input ASCII   Starter HyperCrash
HyperMesh
Runname_run#.rad Engine input ASCII   Engine Engine
Runname_run#_cpu#[_C].rst Restart file Any Default binary Engine Starter
Engine
Runname.h3d Animation H3D   HyperView HvTrans thru run script
RunnameTnn
Runname_run#.thy
RunnameTnnx
Runname_run#_x.thy
Runname_run#.out Output ASCII     Engine
according to the /IOFLAG keyword:
if Irootyy = 2: RunnameYnnn
if Irootyy ≠ 2:
Runname_#run.sty
Runname_nnnn.sta State file ASCII   Starter Engine
Runname_run#.ctl Control file ASCII   Engine User
run#: RADIOSS run number (four digits) from 0000 to 9999
cpu #: number of processors (four digits)
cpu # = 0001 to 9999 = SPMD RADIOSS Version
Version 5.1
5x extension Type Format Remark Read by Written by
HyperMesh
HyperMesh
Engine
RunnameTnn
Runname_run#.thy
RunnameTnnx
Runname_run#_x.thy
Runname_run#.lis Listing ASCII     Engine
Runname_nnnn.out or RunnameYnnn
if Irootyy = 0: RunnameYnnn
if Irootyy = 1: Runname_nnnn.out
Version 4 and Earlier
4x extension Type Format Remark Read by Written by
RunnameD00 Starter input ASCII   Starter HyperCrash
HyperMesh
RunnameD0A Starter input ASCII   Starter HyperCrash
HyperMesh
RunnameDnn Engine input ASCII Default binary Engine User
RunnameRnn Restart file Any   Engine Starter
Engine
RunnameTnn Time history Any Default IEEE binary HyperGraph Engine
RunnameTnnx Time history Any Default IEEE binary HyperGraph Engine
Runname@Tnn MNOISE file Any   HyperGraph Engine
RunnameLnn Listing ASCII     Engine
RunnameYnnn Output ASCII   Starter Engine
RunnameCnn Control file ASCII   Engine User
