Axisymmetric Spring TYPE25 (/PROP/SPR_AXI)
This spring is a simplification of spring TYPE13; in which the properties of the spring cross-section are considered to be invariable with respect to Y and Z.
That allows you to simplify input formats to avoid errors. For further information about this spring, refer to Radioss Starter Input Manual or the Radioss Theory Manual.
