Other Macros Toolbar
The Other Macros toolbar provides you quick access to the Calculate Angles, Find Connected Entities, Create Markers for Deformable Surface, and Contact Properties Editor macros.
Calculate Angles | Allows you to calculate spatial and planar angles between points. |
Find Connected Entities | Allows you to you to find entities which are connected to a selected entity (body, joint, or bushing). |
Create Deformable Surfaces from FEM | Allows you to quickly create a matrix of explicit markers to be used in defining a deformable surface. |
Contact Properties Editor | Allows you to edit the various contact forces applied to a model. |
