Force Entity Toolbar
The Force Entity toolbar provides you quick access to the Forces, Modal Forces, Bushings, Fields, Spring Dampers, Beams, Polybeams, and Contacts panels.
Forces | Allows you to create forces and to edit the orientation and properties of forces. |
Modal Forces | Allows you to include a distributed force on a flexible body that exists in the modal form in the flexible body H3D. |
Bushings | Allows you to edit the orientation, connectivity, stiffness, damping, and preloads of bushings. |
Fields | Allows you to create and edit fields to relate forces between two bodies. |
Spring Dampers | Allows you to edit the connectivity, properties, and initial conditions of springs and dampers. |
Beams | Allows you to edit the connectivity, properties, and orientations of beams. |
Polybeams | Allows you to edit the connectivity, properties, and points of a polybeam. |
Contacts | Allows you to set contact data. |
