Find Connected Entities
This tool allows you to find entities which are connected to a selected entity (body, joint, or bushing).
Figure 1. Find Connected Entities Panel
Find entities connected to | ||
Body | Select to activate the Body input collector/panel. | |
Joint | Select to activate the Joint input collector/panel. | |
Bushing | Select to activate the Bushing input collector/panel. | |
Body/Joint/Bushing input collector | Define the body/joint/bushing to which the entities are attached. | |
Clear Selection | Clears the connected entities information listed in the text box. |
