Cos
Stores the cosine of the src in answer.
src
A value table.
format
deg (default) or rad.
Outputs
answer
A value table.
  • src and answer must be of the same binding and format.
  • If src is a constant value table (created by the Constant operator), no records will be added to the answer table.
  • src must be a real value table, and it must be consistent with the format argument.
cos(src)
XML Example
<call name="Cos" src="src_tab" answer="ans_tab" />
