PlyAxisVector
Transforms a vector relative to the elemental ply system to the global system.
elems
An element entity table.
coords
A coordinate vector value table.
systems
A system entity table.
parts
An part entity table.
mattheta
An elemental scalar table of material angle offsets.
plytheta
A property scalar table of ply angle offsets.
vector
A vector relative to the material system.
Outputs
answer
A elemental vector value table.
  • All vectors in coords must be relative to the global system.
  • Only shells will be processed by this operator.
  • The vector string is a space-separated list of three scalar values.
PlyAxisVector(coords,elems,systems,parts,mattheta,plytheta,vector)
XML Example
<call name="PlyAxisVector" vector="1 0 0"
coords="coord_tab" systems="sys_tab"
elems="elem_tab" parts="part_tab"
mattheta="mat_theta_tab" plytheta="ply_theta_tab"
answer="ans_tab" />
