Select the Impactor Type and the Corresponding Options
  1. From the Impactor Type drop-down menu, select Head, Upper Leg, or Lower Leg.
  2. From the Solver Type drop-down menu, select Radioss or LS-DYNA as the solver result type.
  3. Enter a value for Node Id Adult Head or Node Id Child Head to be used for the section cut in the model.
  4. Enter the Front Comp Ids to display only the required vehicle front components for the results.
  5. Select a Regulation Type from the drop-down menu.
  6. Enter a percentage for the HIC Target Scale.
  7. Select a HIC Window time from the drop-down menu.
  8. Update the HIC notes by clicking Update HIC Notes.
  9. If the Use SAE filter option is activated, select an SAE filter method from the drop-down menu.
  10. You can also select the Overlay Wad lines on the vehicle and Show Displacement Contour options to customize your plot results.
  11. Select Use four window layout if you want to display more than one graph per output.
