Graph Parameters
Select the Y-Type, Y-Request and Y-Component.
The options available depend on the Impactor Type that you select. If both Adult and Child points exist in the target CSV file, then there will be two prompts to select adult and child.
Head Impactor
If Head Impactor is selected, the tool asks for the Y-type, Y-request, and Y-component of the first location for both the Displacement vs Time graph and the Acceleration vs Time graph. From the next point forward, it looks for same Y-Type, Y-request, and Y-component. If the same Y-Type is present but Y-request is not available, then the tool checks if there is only one Y-request. If more than one Y-request is present, you need to input the Y-request for the respective point.
Upper Leg Impactor
If Upper Leg Impactor is selected, the dialog is displayed twice to select the Y-Type, Y-Request and Y-Component: first to plot the Resultant Force vs Time and then to plot the Bending Moment vs Time graphs.
Lower Leg Impactor
If Lower Leg Impactor is selected, the dialog is displayed three times to select the Y-Type, Y-Request and Y-Component for the Knee Bending Angle vs Time, Knee Shear Displacement vs Time and the Upper Tibia Acceleration vs Time graphs.
Note: This dialog is displayed only while post-processing the first deck's results. For the remaining decks, it takes the Y-Type, Y-Request and Y-Component selected for the first deck.
