Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply
shapes for subsequent design optimization studies.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating
the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
From the HyperGraph menu, select Radar
Chart to display the Radar Chart ribbon.
You can use HyperGraph to plot vector, phase vs.
magnitude, and radar plots. Use radar plots to plot complex data. The phase axis for
a radar plot is equivalent to the phase axis for a complex plot. The mag-axis for a
polar plot is equivalent to the magnitude axis for a complex plot. The key
differences are plotted polar coordinates - only a single frequency is
displayed.
Figure 1. Radar Chart Ribbon
Define
Edit existing curves and add new curves to the current plot.
Datums
Add horizontal and vertical datum lines to plots.
