Create and View Section Cuts
Use the Section Cuts tool to cut planar or spherical sections through a model.
Note: The following covers section cuts in HyperMesh. For information on section cuts in HyperView, see the Results Data chapter.
Create Section Cuts
  1. From the View Controls toolbar, click .
  2. In the Section Cuts dialog, click to create a new section cut.
  3. Click of the left side of the microdialog to select either a planar or spherical section cut.
  4. Change the display and position of the section cut using the other microdialog options.
    • Display only the section cut by clicking .
    • Reverse the part of the model that is hidden by clicking .
    • Trim elements along the plane/sphere to create a smooth section cut by clicking .
    • Translate or rotate the section cut using graphical manipulators by clicking . For spherical section cuts, the yellow manipulator can be used to adjust the radius of the sphere.
      Tip: You can also click and drag the frame directly. After exiting the section cut tool, these frames remain visible, allowing you to translate or rotate a section cut at any time. For planar section cuts, click and drag the center of the frame to translate. Click and drag a corner or an edge to rotate.
    • Align the section plane to the x, y, or z-axis by clicking .
      Note: Only available for planar section cuts.
    Figure 1. Planar Section Cut
    Figure 2. Spherical Section Cut
After creating a section cut, it is added to the Model Browser as a Cross Section entity. Its basic parameters can then be changed in the Entity Editor. To edit and adjust a section cut in the tool, right-click on it in the Section Cuts dialog and select Edit.
Figure 3.
The display of the section cut frame can be changed at any time using standard Show/Hide operations. Note that this does not make the section cut inactive.
View Section Cuts
  2. In the Section Cuts dialog, enable the checkboxes of the section cuts you wish to view.
    Figure 4.
