Export Optimization Deck
Export of optimization solver deck.
Using the Export Optimization Deck panel, you can export the solver deck and also perform Fourier Transformation if required.
Below is the Export Optimization Deck task panel-
  1. Select required type from Windowing type list.
  2. Enter a value for No. Of Blocks.
  3. Enter percentage value for Overlap (%).
  4. Click .
    A file browser will appear. Browse and select the required folder.
  5. Click Export.
    This will export the optimization solver deck to the selected folder. Once the export is complete, an user message will appear to navigate the exported location.
Export Solver Deck Options
Windowing Type
A typical modal transient run is a time based analysis. For optimizing the E-line for systematic or a non-systematic optimization problem in the frequency domain, we need to convert the time domain data in the input deck to the frequency domain.
Altair Compose takes care of this conversion in the back end using some of the basic inputs required for the FFT (Fast Fourier transform).
Based on the type of windowing option in time to frequency conversion, the default parameters automatically populate.
Hanning
This window function has a sinusoidal shape and results in wide peak but low side lobes.
Touches zero at both ends eliminating all discontinuity.
This is satisfactory in 95 percent of cases.
Uniform
Is also called No Window or Rectangular Window.
The signal is convolved with a rectangular-shaped window of uniform height, by the nature of taking a snapshot in time of the input signal and working with a discrete signal. This convolution has a sine function characteristic spectrum.
Number of Blocks
Perform a block based FFT where the signal is processed by breaking it into given no of blocks and suitable windowing technique is used to reduce the effects of the leakage.
Overlap (%)
Overlap percentage is also a measure to reduce the truncation effects.
The overlapping windows with suitable windowing type like hanning or uniform helps in providing smooth transition from one block to the next.
