Study the squeak and rattle issues under combined loading conditions.
Using the Combined Loadings task panel, you can review and
analyze the effects of Dynamic and Static loads on the gap and relative
displacement.Note: Combined Loadings activates only when
dynamic and static loadcases are identified in the imported model
file.
Select Combined Loadings tab in the tool.
Combined Loadings tab appears.
Select a loadstep from Loading type 1 list.
Select a static loadstep from Loading type 2 list.
Enter Scale factor values.
Optional: Check Affects gap
box.
Select required E-Line or All from E-Line(s)
Selection list.
Select required analysis type from Session Type.
Available analysis types are-
- Summary Analysis
- Full Analysis
Click Combine Results.
This evaluates the combined effect of the selected loadsteps on the E-Lines and plots all the required results, relative displacement
and histograms.
