Sensitivity Analysis
Use Sensitivity Analysis to study modal contribution.
The standard post-processing in SnRD offers the functionality to generate time domain displacement plots of each of the node-pairs of all the E-lines that are present in the model. The purpose of the Sensitivity Analysis is to study the root cause of rattle and/or squeak at each E-Line.
- Determination of Relative Modal Contribution to squeak and rattle of complete E-Lines and as well as at specific points on each E-Line
- Capability to check the effect of changing the percentage of modal contribution on the squeak and rattle performance
Preparation for sensitivity study.
E-Line Selection
Modal Sensitivity Studies
Study the modal contribution and sensitivity.
The sensitivity analysis is a two step process.
- The first step is to calculate the relative Modal Contribution of the required E-Line to be analyzed.
- The second step is to observe the change in results, when the modal
contribution is varied buy either including or excluding a certain mode from
the result calculations with the help of Modal
Sensitivity study. The relative modal contribution for a
particular E-Line can be calculated and studied in two ways:
- Study the modal contribution of the complete E-Line
- Study the modal contribution of a particular node pair of an E-Line
Modal Contribution
Maximum Peak
% of Highest Peaks
Modal Sensitivity
The Modal Sensitivity study can be performed on complete E-Line or a selected Node pair belonging to an E-Line. Once the Modal Contribution study is done and you have determined the modes that exhibit maximum contribution to the relative displacements that lead to squeak and rattle, you can study the effect of particular mode(s) on the total response.
SnRD computes the total response (relative displacement) based on the equation of motion without need to simulate again. This enables to understand the potential of a design change that leads to damping or eliminating a certain mode shape.
Chosen modes can be Included or Excluded from the results and displacements recalculated to observe their effect on the squeak and rattle performance.
Sensitivity Analysis Options
- Result File
- List contains the results file loaded in the Post Processing tab.
- Subcase Name
- List containing the subcases of the selected results file.
- Modal Result File (h3d)
- H3D file containing the modal contribution results.
- Display Excitation Load
- This option will be active only for a node pair and not for complete line option.
- 2D Squeak Plot
- Adds an additional plot with the relative displacement in contact plane (XY) for squeak lines.
- Modal Contribution
- Max. Peak
- To study the relative displacement study for the peaks and time of occurrence.
- % of Highest Peaks
- To study a certain percentage of highest peaks.
- Modal Sensitivity
- Select Contributors
- Include- Includes the selected modes in the recalculation of the displacements
