DoE / Stochastics
Use DoE/Stochastics to understand the parameter variation study.
Evaluate DoE/Stochastics
Steps to evaluate DoE/Stochastics runs.
DoE/Stochastics Options
Description of DoE/Stochastics Options
- HyperStudy Results Database
- To generate a results database for the DoE/Stochastics runs.
- SnR Results Database
- To use previously created runs database using DoE/Stochastics.
- Data Filtering
- Active Database
- Select active database for post processing.
- Selection
- Select required options for-
- Show Runs
- Option to display runs for-
- Vary Variables by
- Value- actual value used in the run.
- Show Variables
- Select the variation parameters used for conducting the runs.
- Evaluation Criteria Update
- Regeneration of a new Database XML for all Stochastic Runs for a different GD&T/Impulse Rate data file.
