poIGraphicMaterial SetSpecular
Sets the specular highlight color of the graphic material.
poIGraphicMaterial_handle SetSpecular specular
HyperView Tcl Modify
This command sets the specular highlight color of the graphic material.
Note: Values approaching 1.0 simulate a smooth, shiny surface; while values approaching 0.0 simulate a rough surface.
shininess
The specular color in a space-separated RGB string, ranging in value from 0.0 to 1.0.
Returns 0 if successful, otherwise an error code.
