poIGraphicMaterial GetShininess
Gets the material shininess value.
poIGraphicMaterial_handle GetShininess
HyperView Tcl Query
This command returns the material shininess value.
None.
Gets the material alpha transparency value.
Gets the ambient color of the material.
Gets the diffuse color of the material.
Gets the emissive color of the graphic material.
Gets the graphic material ID.
Gets the graphic material label.
Gets the metallic value of the graphic material.
Gets the roughness value of the graphic material.
Gets the specular color.
Sets the alpha transparency value.
Sets the ambient color of the material.
Sets the diffuse color of the material.
Sets the material emissive color.
Sets the graphic material label.
Sets the metallic value of the graphic material.
Sets the roughness value of the graphic material.
Sets the material shininess value.
Sets the specular highlight color of the graphic material.
ON THIS PAGE
HyperView Tcl Query
None.
ON THIS PAGE
