Gets the color for the Stress Characterization Line (SCL).
Gets the ID for the Stress Characterization Line (SCL).
Gets the label for the Stress Characterization Line (SCL).
Gets the begin point for the Stress Characterization Line (SCL).
Gets the end point for the Stress Characterization Line (SCL).
Gets the number of points on the Stress Characterization Line (SCL).
Gets the review state for the Stress Characterization Line (SCL).
Gets the option used to use intersections of the path with elements as intermediate points.
Sets the color for the Stress Characterization Line (SCL).
Sets the label for the Stress Characterization Line (SCL).
Sets the begin point for the Stress Characterization Line (SCL).
Sets the end point for the Stress Characterization Line (SCL).
Sets the number of points on the the Stress Characterization Line (SCL).
Sets the review state for the Stress Characterization Line (SCL).
Specifies whether to use intersections of the path with elements as intermediate points.
ON THIS PAGE
ON THIS PAGE
