Gets the use corner data state.
Gets the data component of this result definition.
Gets the data type of the result definition.
Gets the ID of the vector result definition.
Gets the label of the result definition.
Gets the layer of the result definition.
Gets the layer filter of the result definition.
Gets the loaded status of the result definition.
Gets the result system of the result definition.
Gets the poISelectionSet handle of this result definition.
Gets the size of the selection set for a result definition for the specified model.
Gets the show midside node results state.
Gets the type of this result definition.
Sets the use corner data state for a result definition.
Sets the data component of the result definition.
Sets the data type of the result definition.
Sets the label of the result definition.
Sets the layer of the result definition.
Sets the layer filter of the result definition.
Sets the result system of the result definition.
Sets the selection set which defines the entities of this result definition.
Sets the show midside node results state.
ON THIS PAGE
ON THIS PAGE
