poIVectorDefine SetLayer
Sets the layer of the result definition.
poIVectorDefine_handle SetLayer layer
HyperView Tcl Modify
This command, valid only in Upfront Data Loading Mode, sets the layer of the result definition. Returns Success (0) or an error code.
Note: The result definition can only be modified if it is not cached.
layer
The result definition layer.
To set the layer of a vector result definition to Upper:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client GetResultHandle vdefine 3 vector
vdefine SetLayer Upper
hwi CloseStack
None.
See the Upfront Data Loader APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
