Gets the data component of the result definition.
Gets the nodal variation factor.
Gets the nodal variation factor enabled state.
Gets the averaging mode.
Gets the list of valid averaging modes.
Gets the average across parts enable state.
Gets the complex filter.
Gets the use corner data state.
Gets the data type of the result definition.
Gets the envelope tracing entity.
Gets the envelope tracing entity list.
Gets the feature angle average value.
Gets the feature angle enable state.
Gets the ID of the scalar result definition.
Gets the ignore flipped normal state.
Gets the multiple layers state.
Gets the label of the result definition.
Gets the layer of the result definition.
Gets the layer filter of the result definition.
Gets the loaded status of the result definition.
Gets the currently selected list of multiple layers.
Gets the projection axis information.
Gets the result system of the result definition.
Gets the poISelectionSet handle of the result definition.
Gets the size of the selection set for a result definition for the specified model.
Gets the show midside node results state.
Gets the type of this result definition.
Gets the value filter values.
Gets the value filter type.
Sets the nodal variation factor. Specify the threshold variation level above which nodal averaging should not be carried out.
Sets the nodal variation factor enabled state.
Sets the averaging mode.
Sets the average across parts enable state.
Sets the complex filter.
Sets the use corner data state for a result definition.
Sets the data component of the result definition.
Sets the data type of the result definition.
Sets the envelope tracing entity.
Sets the feature angle average value.
Sets the feature angle averaging enable state.
Sets the ignore flipped normals enable state.
Sets the multiple layers state.
Sets the label of the result definition.
Sets the layer of the result definition.
Sets the layer filter of the result definition.
Sets the multiple layers list.
Sets the projection axis information.
Sets the result system of the result definition.
Sets the selection set with defines the entities of the result definition.
Sets the show midside node results state.
Sets the value filter values.
Sets the value filter type.
ON THIS PAGE
ON THIS PAGE
