poIGraphicMaterial GetMetallic
Gets the metallic value of the graphic material.
graphic_material GetMetallic
HyperView Tcl Query
This command returns the metallic value of the graphic material (float 0.0 to 100.0).
To get the metallic value of a graphic material:
hwi OpenStack
session_handle GetClientManagerHandle post_manager_handle Animation
post_manager_handle GetGraphicMaterialHandle brass 3
brass GetMetallic
hwi CloseStack
None.
