poI3DViewCtrl SetZOffset
Sets the z offset of a stored view.
poI3DViewCtrl_handle SetZOffset offset name
HyperView Tcl Modify
This command sets the z offset of a stored view.
offset
This value represents the distance from the near to far clipping planes which affect the perspective. It will have no effect in the orthographic projection.
name
String specifying the name of the view to be modified. If a name is not specified, the current view will be modified.
To set the z offset of a view named "View 1" to 500:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetViewControlHandle view_handle
view_handle SetZOffset 500 “View 1”
hwi CloseStack
Error
Returns HW_InvalidHandle if the view handle is invalid.
Returns HW_InvalidArgs if the named view does not exist.
