poI3DViewCtrl GetUpOrientationMethod
Gets the orientation method of the camera top position.
viewControl_handle GetUpOrientationMethod name
HyperView Tcl Query
Returns the orientation method used to define the camera top position.
name
String specifying the name of the view to be queried. The current view will be queried if a name is not specified.
To get the orientation method defined for a view named "View 1":
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetViewControlHandle view_handle
set orient_method [view_handle GetUpOrientationMethod “View 1”]
hwi CloseStack
Error
Returns HW_InvalidHandle if the view handle is invalid.
Returns HW_InvalidArgs if the named view does not exist or is an invalid type.
