poI3DViewCtrl RemoveView
Removes a view from the list of memorized views.
poI3DViewCtrl_handle RemoveView view_name
HyperView Tcl Modify
This command removes a memorized view from the memorized views list.
view_name
The name of the view.
To remove the specified memory view:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
window_handle GetViewControlHandle viewctrl_handle
viewctrl_handle RemoveView “view name“
puts "Current View: [viewctrl_handle GetCurrentView]"
hwi CloseStack
Error
Returns an error if the view control handle is invalid, or if the memorized view name could not be found.
